I'm planning on putting a 3in BL on to get it up off the ground. How big of tires will i be able to fit with that lift?
Im sure 30's would fit. I would look into a fabtech lift though. A few more dollers but better ride and look cleaner then body lift unless you get gap guards. Another way for lift and free is crank the t bars up. Again not great ride quailty but its free.
Might wanna look into a suspension lift. If its a 2wd you could get an add-a-leaf and a lift shackle for the rear. The front you can either do torsions and a ball joint spacer or UCA and torsions. Most ball joint spacers will not work with the spacer
