Starting then dying
Discussion in 'Maintenance/Repair' started by kingtoy, Aug 22, 2012.
  1. kingtoy
    kingtoy Enthusiast
    Cedar Hill, Texas
    1993 Toyota std cab, 1977 Hilux
    My 93 4 cyl truck has developed a strange quirk lately. It has odd thing where sometimes, I start it and within a second or two it dies again. Giving it gas doesn't help either. Sometimes this can go on for 16 starts or so. The strange thing is it doesn't always do it everytime. Does anyone have any idea what could be causing it?
  2. White Trash
    Sounds like the afm is dropping signal occasionally. Check the air tube between the afm and throttle body for vacuum leaks.
  3. kingtoy
    kingtoy Enthusiast
    Cedar Hill, Texas
    Hmmm ok, I will give that a look.
  4. kingtoy
    kingtoy Enthusiast
    Cedar Hill, Texas
    Well I checked the intake tube and all seems sound and tight so I don't think that is the issue. Anyone else have any suggestions?
  5. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Maybe distributer/ ignitor problems or fuel pump relay or a short not to familiar with 22re quircks
    Just throwin it out there
  6. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    I would start by checking for vacuum leaks. Then maybe replace fuel filter. Yours may be clogged. Then check all ignition components plugs, wires, cap, rotor. Thats where i would start. And of none of those help let us know.
  7. IronNam
    Look over all ground points to be safe.
    check spark. check fuel.
  8. kingtoy
    kingtoy Enthusiast
    Cedar Hill, Texas
    Well since it doesn't do it 100% of the time, and it does eventually start. I don't think it is a ingnition problem. I did start to wonder about fuel delivery though. I think it might just be a clogged fuel filter. I bought one today, so I will replace it tomorrow and see if it goes away. I will report what happens.
  9. kingtoy
    kingtoy Enthusiast
    Cedar Hill, Texas
    Well I changed the fuel filter but it seemed that wasn't the problem. Anyone new ideas on what it could be?
  10. IronNam
    wiggle some connectors, check the igniter and make sure it's grounded.
  11. kingtoy
    kingtoy Enthusiast
    Cedar Hill, Texas
    Well I have now replaced the fuel filter and the fuel pump and it still has the problem.
    Does anyone have any suggestions. I am running out of ideas. :doah::doah:
  12. raylcc
    raylcc Addict
    Denver, CO
    Just because the problem in intermitent doesn't mean that its not a ground or ignition problem. I would do like was said before and check the wiring over pretty good. You'd be amazed how much frustration can be caused by a single frayed wire when your trying to diagnose a problem,
  13. kingtoy
    kingtoy Enthusiast
    Cedar Hill, Texas
    I looked around for frayed wires but haven't found any yet. I will look again. A mechanic friend of mine said it might be the EFI relay or something.
  14. donellk
    donellk Member
    Palm Bay
    '93 Toyota Pick up
    My truck is having the same issue... It'll start then stall a second later... I replaced the efi relay but nothing... Read the it might be the open cercit relay but I jumped the fuel pump and I can hear it running but still stalls after I try to start... My next guess is fuel pressure regulator but I'm not sure! I got it to run off starter fluid but it seems it isn't getting gas I figure is its anything other then a gas issue it wouldn't run off starter fluid =\
  15. donellk
    donellk Member
    Palm Bay
    '93 Toyota Pick up
    Ok my trucks running... on the driver side im guess its the ignition coil? a wire came loose from the butt connector the guys before me had done... fixed and is running good again! Hope this helps you
