difference between early and late heads
Discussion in 'Engine/Drivetrain' started by oilspot, Apr 4, 2012.
  1. oilspot
    oilspot Member
    I picked up a 22r out of a truck made in July 84. I'll be slowly rebuilding it for my 94' EFI truck.
    I see on the lc engineering site that they have a 81-84 head, and then a 85-95 head. How can i figure out if the motor i have is the early or later version. Not sure what month Toyota decided to switch to being considered a 85 that year.
    Just need to make sure it's the right head before I drop it of to have it redone!
  2. dillinja666
    Find the plug cast on later model 22R engine blocks. According to Ice Engineering's Tech FAQs, there is a cast, bow-tie shaped plug just before the oil pan rail, below the middle freeze plug on the driver's side of the engine. This presence of this plug indicates a 1985 to 1995 22R/22RE "Laser Block." Earlier 22R engines do not have this feature.
  3. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    What shape is the exhaust port?
  4. oilspot
    oilspot Member
    Round.... ****!
    Well at least now i know how to tell em apart.
    Next question. Is the short block compatible with the newer style head?
  5. oilspot
    oilspot Member
    This question is got me at a standstill? I see that there are different part numbers for the rebuild kits. But do the older shortblock work with the newer head, and existing EFI system in my 94'?
  6. CUCUY
    CUCUY Enthusiast
    HOUSTON
    '81 SR5 longbed
    "In 1985- the 22RE had a major change. The block was taller and the head shorter, compared to the earlier models. The engines' blocks and heads are not interchangeable (for practical and cost purpose). "
    22R Tech Notes
