Oil pan gasket
Discussion in 'Maintenance/Repair' started by mandinvw, Mar 16, 2012.
  1. mandinvw
    mandinvw Newbie
    1979 Toyota Pickup 1ton
    I HAD A VERY BAD LEAK ON MY 22RE, I DECIDED TO CHANGE THE GASKET, I BOUGHT THE PUTTY, IT WAS A PAIN TO GET DOWN AND UP, FINNALY I GOT IT BACK TOGETHER AND I HAVE A BIGGER LEAK !!!:brickknock:
  2. Houa Thao
    Houa Thao Enthusiast
    Sacramento, ca
    91extracab
    I did mine about six months ago with the gasket seal stuff and it work fine. Just have to clean it very good before you apply them on.
  3. 89yotanut
    89yotanut Member
    Norwood, Colorado
    89 4runner,85 xtra cab,81 custom cab dually, 78 fj55,83 LWB sr5 4x4, 82 SWB 4x4
    Get the right gasket, hold in place with multi purpose grease and make several rounds around the pan before finishing off to the correct torque specs. there is different specs for different years so make sure you get the right torque specs. Make sure to look close at whether it is inch or foot #'s big difference! and watch your gasket as you start to get snug, you dont want to over tighten!
    Dont forget to use a little silicone at the timing cover corners and at the rear main corners.
  4. Cajun83 Sr5 4x4
    Cajun83 Sr5 4x4 Newbie
    Baton Rouge LA
    1983 Sr5 4x4
    Toyota dealers sell a black silicone liquid gasket. cost around $20.00 but it works great.clean mounting surfaces and it drys fast once you put the pan in. 20mins you can have the motor running.
