Imporveing gas mileage on a 22r
Discussion in 'Engine/Drivetrain' started by toy_spd, Dec 1, 2011.
  1. toy_spd
    toy_spd Addict
    So.Cal -
    92 SR5 V6 Extra Cab
    I am currently averaging 28mpg and I can get 350miles out of the tank if i push it, tank is a 13 gal tank. I commute 100 miles round trip to work. I want to get more MPG out of the tank.
    Truck is a 90 22R federal emissions 49 state truck and has new spark plugs, wires, cap rotor, air filter, fuel filter, all oils everywhere have been changed and tires are at 32 psi.
    To my knowledge the carb has never been rebuilt, truck has 227k on it, I got it with 214k. when I 1st got it i was getting 21-23mpg freeway.
    What are some ideas as to improving gas mileage?
    I am looking into having the carb rebuilt, but am hesitant because the truck is running really good right now.
  2. Litneon
    Yeah. I'd say that's about as good as I've ever heard of one of these getting. I get around 24 MPG or so with my 22RE.
  3. dOBER
    dOBER Member
    I have the same set up getting about the same mpg in an 1988
    couple things i've been considering
    LT 185R14 tires. They can be pumped up to 55-60 psi for extra load. they would roll a lot harder and should get a bit more mpg vs std 44psi Passenger tires.
    lowering the front improving aero drag.
    Mine is currently w a 4spd. i drive 55-65. Maybe if it breaks, look to find a 5 speed.
    maybe a homemade hydrogen cell and leaning out the mixture a little?
    theres a few ideas
  4. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    I would pump your tires up to a good 45 50 psi. if they are in good shape. you will see a differance. But im pretty sure the only thing you can do to get better mileage is slow down on your drive. find your trucks sweet spot cruising speed.I would fill your tank up right before your commute and fill up again when you get back, and do that every day but change your speed a little, and see which one is the best.
  5. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    I'm getting 24 pretty consistently. I've gotten up to 28 for a single tank on the highway keeping off the gas going 65-70 mph. that's with FI, 5 speed, and freeer exhaust. Since the gearing is pretty aggressive (almost 3k @ 70) speed is going to be the biggest killer. getting more than 28-30 mpg is going to take a lot of effort (like swapping 5th gear from a W58 for the 2-300 rpm drop at 70)
    FYI the 4 speed/3.08 combo gives the same highway revs as 5 speed/3.73.
  6. SD YOTA
    If your truck is federal, then its got the 4 speed more than likely. Swap the 5 speed in and 5th gear will give you a little better freeway rpm drop.
    Dropping it low as mentioned will also improve mileage as aerodynamics are improved.
    I would leave your carb alone. Unless you experience issues, you still hsve lots of trouble free miles left on it. You can run a k&n filter if you want to improve air flow and lessen the restriction. With it, a good free flow exhaust will help out as well.
    Synthetic oil would be a good upgrade and you can also see a change in mileage as well. As for your tranny and diff, synthetics will also help in the same way there.
  7. toy_spd
    toy_spd Addict
    So.Cal -
    92 SR5 V6 Extra Cab
    Its a 5 speed i'm sure of it, lol unless i'm changing into an imaginary gear, lol
    as far as the axle code and Trans they are F382/G57 - a 5 spd with a 7.5" rear and 3.417 gears according to the vin decoder on 4x4 wire. The carb I will be leaving it alone for now.
    I'm going to try the stock size wheels and see how that works out as well.
    I'm also trying different shift points too.
  8. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    When my 82 was bone stock, I got 32MPGs easy IF I drove 55mph. That 55 is on the speedo for a reason. Its the sweet spot :lol:
    Now with my big holley it gets about 20. But its significantly faster.
    Oh and when I swapped a 4 speed for a W58, my gas milage went down. :shrug: I think it got it out of the torque peak.
  9. geonbugman
    geonbugman Member
    Columbus
    93 Pick-up
    NEVER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Exceed the posted presure for the tires. You should always set your tire presure to the factory vehical specification. Over inflating your tires might increase gas millage but at the risk of control. All car manufactures spend millions on tire safety. Is gas millage worth risking your life, maybe? But your not the only one on the road.
  10. IronNam
    I got a W58 + 8" 3.41's (xcab 22re btw) and with the incorrect speedometer and odometer, i got calculations (incorrect) of 20 something mpg's... that's with driving around hard. I'm sure I get better...
    I do 2000rpm's at 60mph and ~2500 around 70mph.
  11. yota4life
    Well my speedo doesn't work but I drove to Bakersfield an back on one tank which is close to 500 miles. Which is averaging about 28mpg don't kno how fast I was goin but I have over 200,000 on my 22re
  12. toy_spd
    toy_spd Addict
    So.Cal -
    92 SR5 V6 Extra Cab
    Anyone know if a 17 Gal extra cab tank will fit a single cab? Im going to look at the trucks at the pick a part and see if they can fit with some work.
  13. yota4life
    I'm gonna say it won't but I cud be wrong. Maybe with some new
    brackets it will
  14. geonbugman
    geonbugman Member
    Columbus
    93 Pick-up
    I get a soild 19mpg city buy like Cinn, I drive hard (Yes it's all about cornering) I have a stock 22re, stock exahust, Stock ratio, on 8.5 wide tires. Highway only goes up a little to 21mpg. But every stop light is a drag race and every interstate is an excuse to shave off a little time. I'll try free flowing exhaust and battery A/F neter swap soon but I think it will be worth an un-noticable amount. I do know that an ignition upgrade would help alot in all aspects; better starting hot or cold, better gas millage, more complete fuel burn (you can run a larger gap on the plugs so that will improve the flame travel in the cylinders), and most important all this means more over all horse power. other than that you could try bumping up the timing a little, it would help top end economy if you spend alot of time in the upper RPM range. You will loose a little on the bottom end because drivability will suffer slightly. you could also try a pour in millage improver, however this might off set the fuel cost savings. Just like a timming adjustment a taller tire will help improve top end fuel millage but at a cost of having to work a little harder to get going from a stop. I will say that shaving a few inches from the ride height, and putting on a chin spoiller did give me a full 1mpg.
  15. Litneon
    This is only accurate if you use the exact same tires that came on the vehicle. While I am not advocating overinflation, the actual pressure needed will depend on the load rating of the tire and the actual load the tire sees.
    For example, if the tire will support 3000 lbs @ 30 psi, you can figure that the tire will support 100 lbs for each psi. If you have 1200 lbs on that corner of the vehicle, you only need 12 psi carry that corner. At 12 psi the tire should wear relatively even, although some adjustment may be needed to dial it in (the chalk line test works great).
    On my old 4runner, I ran 13 psi in the fronts and 9 psi in the rears. The tires wore evenly and handling was what you'd expect from a 4wd.
    In my current truck, I run 39 psi in the fronts and 23 psi in the rears.
  16. Under Construction '93
    Under Construction '93 Addict
    Riverside,Ca
    1993 Std Pickup
    :funnyup: Every tire has a max operating pressure on it. As long as you dont exceed that your fine. Usually better tires have a higher max pressure as well...
  17. geonbugman
    geonbugman Member
    Columbus
    93 Pick-up
    Yes every tire has a max value, however just because you can dose'nt mean you should. I have to agree with the last post though the chalk test works best, but just plain over inflating the tires to decreese rolling resistance by making it ride on a smaller contact patch is not smart............... ..:verdict_in:...... It's not a matter of overcomming the presure raiting of the tire, it's about lowering the ability of the tire to grip the road safely.
  18. geonbugman
    geonbugman Member
    Columbus
    93 Pick-up
    I stand corrected, your right the chalk test wors best.:doah: BTW nice truck.
  19. yota4life
    Anymore pics of tht runner!?
  20. 808'
    808' Enthusiast
    Kaneohe, Hi
    85 single cab
    Be happy with your mileage lol.
    Also be happy your not paying $4.20+ for a gallon of gas, over here you can even find it for up to $5gal.
