Side Draft Carb?
Discussion in 'Engine/Drivetrain' started by Salty, Dec 1, 2011.
  1. Salty
    Salty Enthusiast
    Ive been reading "side draft" alot on this site and was wondering what exactly that meant... i figured its just a side mounted horizontal air intake.... but does my '79 20R have a side draft carb? and if it does how do i go about putting velocity stacks on it?
  2. White Trash
    A side draft carb pulls air from the side straight through the intake into the engine. Most carbs pull air from above the engine then it turns 90* to go into the engine. Those are known as downdraft carbs.
  3. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    your truck does not have it. unless previous owner put it on. they look like ITB's.. heres a picture of my truck with side drafts.
  4. Salty
    Salty Enthusiast
    ive got a downdraft carb with a bulky air filter.
    what sidedraft carb would go on my 20r? what modifications would i have to do, if any?
  5. 75hilux
    75hilux Member
    Sacramento
    75 hilux
    i have a set of side drafts on my 20r and they are amazong u would need tp change the intake manifold and carbs with linkage.. its a totally different setup... very well worth it.
  6. geonbugman
    geonbugman Member
    Columbus
    93 Pick-up
    If your not going inside the motor, keep the carbs small (check the link below). according to edelbrock "you can over carb by as much as 150%, and still be in the corect range for your motor". That being said you will still have to tune for your application and geographical elevation. If you go through a reputable dealer they can assist you in setting up the proper jet and emulsification tube sizes. Also consider cold weather start ups. Other than that they are a blast to drive, they sound great to. Hope this helps.............
    20R Weber 40mm Sidedraft Carburetor Kit
  7. Byronics
    Byronics Veteran
    Hilo, Hawaii
    89' Single cab
    webers ftw:waytogo:
    are those 40's?
  8. HIyota
    HIyota Member
    Hawaii, big island
    1980 toy
    Sick I got 45 webber side drafts on a 20r so cam is kinda needed
