Project Towyard
Discussion in '1984-1988 Build-Up/Project Threads' started by thundering02, Mar 22, 2011.
  1. thundering02
    thundering02 Addict
    Fenton 63026
    Back story:
    I have no knowledge of history on this truck prior to me purchasing it out of a towyard (hence the name)
    Purchased from a little towyard near the house then for all of $400 (local pd writing on the windshield), only plans when purchased were to use it like rental truck with all of my friends. New clutch and u-joint later (less than $100) I had a registered drivable little pickup, just in time to blow the engine in the daily driver and not have project race vehicle running either. Enter truck as daily driver for the next 1.5 years when I sell first of my 240s and buy the BMW getting better gas mileage than the truck now becoming the daily itself, also parted my race project out shortly after that. After getting to at least 4quarts of oil a week while being driven occasionally it finally turned a bearing the 22re(about a month before the last move) and has been sitting in the same spot until very recently when it got moved to a space where I can work on it.
    Plans
    I have a GM350 (5.7l) from a 71 Camaro that could pull the front tires off the ground. Also a th350 3 speed that looks like a low mileage rebuild.
    3 inch lower control arms and 2 inch blocks although I think I'm just going to pull 4 of the 6 leaves (its a 1 ton)
    Just ordered engine mounts and powersteering adapter.
    Pics and more to follow.
  2. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    Cool man what year is the truck??
  3. thundering02
    thundering02 Addict
    Fenton 63026
    ^ 85
    The engine....
    Bored 30 over,12.5-1 comp pistons (keith black) summit stage two rods with arp rodbolts,clevite race bearings, crane solid roller cam 110 lobe seperation, .63 lift, intake and exhaust, chevy double hump heads with screw in studs, large dual valve springs, the intake is a victor 4+4 crane gold roller rockers, crane retrofit solid roller lifters, crane stud girdle, the block has oil restrictors installed. chrome cheverlet valve covers, stock alternator with new chrome alt brackets, newer stock short waterpump, high volume high pressure oil pump(holds 60psi oil pressure when wrmed up)
    Holly 750 doublepump going to be reworked for e-85
    Estimates from some of the GM guys are talking a little above 500hp
  4. RosamondMini
    RosamondMini Enthusiast
    Rosamond, Ca ( So Cal)
    93 Pickup
    That truck will fly with that engine!!!
  5. flacostaco
    flacostaco Toyotaholic
    Corona Southern Cali
    87 pickup
    where the pictures at????
  6. thundering02
    thundering02 Addict
    Fenton 63026
    Only pic I have at the moment... I;m going to try and get back out to work on it again this weekend.
  7. thundering02
    thundering02 Addict
    Fenton 63026
    Engine and steering mounts.
  8. GrantH
    GrantH Addict
    Hattiesburg, MS
    i don't mean to be rude...but your suspension plans may be the worst idea ever for a truck with a motor that, can as you say, pull the wheels off the ground...
  9. thundering02
    thundering02 Addict
    Fenton 63026
    yeah I will go 4 link (beefed taco) at somepoint.. got to get it moving under its own power first.
  10. thundering02
    thundering02 Addict
    Fenton 63026
    More Pics finally ... where and what state its in to start things off with.
  11. standardbyker88
    If it has a leaf pack as burly as you say, it may be just the ticket to keep the back end from getting crazy axle wrap. I wouldn't suggest a V8 to try and hook with less than 3-4 leafs in the pack. Good luck with it. Should be a fun project.
  12. planemos
    planemos Toyotaholic
    British Columbia
    I drive a truck like that around town. It is pretty fun. Decent front brakes. If I wanted to I could make the sandbags in the back smash the rear window. :D:):D
  13. thundering02
    thundering02 Addict
    Fenton 63026
    Ok found out my carb is a Holley 650 doublepump (list 4777-2) instead... Might be a little small for my requirements...
  14. flacostaco
    87 pickup
    sum1 was sellin that on here i think
  15. thundering02
    thundering02 Addict
    Fenton 63026
    ^ nope got it from one of my drifter/240 crowd with the engine that I got from him.
  16. lowplz
    lowplz Member
    Hayward, CA
    87 longbed
    i wouldn't mind that motor
  17. thundering02
    thundering02 Addict
    Fenton 63026
    Torque converter bolts.
    Bolts to connect the trans to the engine.
    14x4 offset airfilter kit to clear the HEI distributor.
    And a coil as soon as I can confirm what I need regarding the distributor.
