Sleepingciv's 1993 yota pick up
Discussion in '1989-1995 Build-Up/Project Threads' started by sleepingciv, May 26, 2010.
  1. sleepingciv
    sleepingciv Enthusiast
    Well it not much to look at right now. But i traded a pos blazer for this and 300.00 lol
    here she is o dont mind the dates lol
  2. sleepingciv
  3. sleepingciv
    took all this crap off lol
    6x8s in the dash now
  4. sleepingciv
    found this lol
  5. sleepingciv
    took these out
    added the 4 inch blocks
    and did this
  6. sleepingciv
    started to paint frame today. its only temp till i get the product i want
    well it finally cooled down some so i finished the rear of the frame. i missed a few spots though lol o well
    and did some more bay work
    can u see the changes???
  7. sleepingciv
    well did some more tonight. I figured since i tucked a little harness, i should it do it all lol
    so started in the cab bla bla bla
    and i always had this smell when i turned the heat on lol well som bitch look at this lol
    this is what fell out of the blow motor housing lol
    and this was still left in there with the pile on the floor
    then started the tuck if ya look at the pervious pics you should be able to notice what i have done :)
    inside after engine harness was ran in
    still need to install fuse box and crap for headlights ect ect
    and relocate battery to the bed
  8. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    Nice little truck. Good start getting her closer to the ground. Tht bedside is torn up
  9. sleepingciv
    ya i hear ya man been searching for a bed or bedside for it. cant find crap for it, well i can but its like a 700 miles or so round trip lol
  10. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    I found a place that sells bedsides they're 234$ it's called rockauto.com
  11. sleepingciv
    thanks ill check that out :D
  12. Predracer
    Predracer Toyotaholic
    Conyers, GA
    Long bed 80 2rz turbo machine
    Nice man, looks like a promising project.
  13. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    does it still run good with removing all those vacuum lines?
  14. jetas
    nice start. yea go to rockauto unless u can get the bedside cheaper.
  15. sleepingciv
    ya man runs better then before lol
  16. priusjames
    priusjames Enthusiast
    Laguna Hills, California
    75 Hi-lux
    Looks like it came with an instant rebate, too! About $1.75? Heh.
    Nice lookin' truck.
  17. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    nice man! hittin the ground and runnin already, great start!
    that throttle body could use a little cleanin too though, probably wouldnt hurt to do a seafoam treatment or two...... :waytogo:
  18. sleepingciv
    lol ya also last night when i removed the grill i found a 10mm grearwrench lo
    ya thanks. Ill prob get to the motor work sooner or later lol
    I wish i had taken pics before i started to work in the bay area. Man the grease dirt film was so thick. You couldnt read the TOYOTA in the vc let alone even see it lol, it was pretty thick
  19. IronNam
    He did the battery disappear mod! ZOMG! haha
    He put the centering block on top of the drop blocks, SMART MAN! finally someone that actually did what I did!
    anyway sir, you're getting somewhere! props on progress
  20. tron93
    tron93 Enthusiast
    Orlando FL
    93 xcab
    Looking good.:clapping: Can you give extra details on how you switched the battery from the rightside to the left. Did you just extend the pos/neg wire? Also which vacumn lines did you plug/remove- looks real clean.
    Thanks
