Dedicated to Toyota Stout, Hilux, and Pickup Owners
Go Back   Toyota Minis > 1989-1995 Pickups > 1989-1995 Pickup Discussion > Wheels/Tires
Reply
Thread Tools Display Modes
Old 01-09-2009, 01:53 PM   #1
JamesD
Veteran
JamesD's Avatar
Truck: 93 Reg cab
Exclamation Starion/Conquest wheels, which ones?
Which ones do I need that will fit my truck correctly? Their is 4 choices. HELP!!
__________________
Toyota 22RTE TURBO PARTS FOR SALE: http://www.toyotaminis.com/forum/showthread.php?t=1280
JamesD is offline   Reply With Quote
Sponsored Links
Toyota Pickup Forum
Advertisement
Old 01-09-2009, 05:49 PM   #2
OJ's DNA
Member
When I get mine from blazinrola I'll let you know, I bought his starion wheels a few weeks back and then I saw the thread noting the 4 different sizes - I assumed they were all one size before that little bit of information.
OJ's DNA is offline   Reply With Quote
Old 01-09-2009, 09:57 PM   #3
FOKAI
Enthusiast
Truck: 84 truck, 05 4Runner
U want the non-SHP ones if your truck is lowered. 16x7's in the front and 16X8's in the rears. I'm not too sure about the offsets. There are a few guys here running them maybe one of them can chime in.
FOKAI is online now   Reply With Quote
Old 01-10-2009, 12:27 AM   #4
SD YOTA
Toyotaholic
SD YOTA's Avatar
Truck: 87 4x4 4Runner / 85 2wd mini
there are 2 sets of fronts.
16x7 with +18 offset
16x8 with +18 offset
there are also 2 sets of rears
16x8 with -11 offset
16x9 with 0 offset
i believe that you can run a set of 8's in the front with some minor, if any fender rolling depending on your drop. the rear is a bit more intriquite. i know for a fact a 16x9R will stick out. a 16x8R will likely still require lots of fender rolling and maybe some bedside stretching. but you should be able to run a 16x8F on the rear with no serious issues. this all greatly depends on the size tires you run as well.
im running a 16x7F wrapped in 205/50/16 tires and 16x8R wrapped in 205/55/16 on my 86. the fronts cleared and tuck tires with minimal rubbing (untill i clear the inner fender wells out) and the rear, even with a 4x4 bed still tend to rub the sidewalls if i tuck them all the way to the wheels. ((i have air shocks so i lifted them till they stopped rubbing.
wheel setup is only 50% of the issue..... tire choice will be the other half.
__________________
86 LoLux pickup 7/6 drop
FR: djm arms, BT spindles, BJ flip, SAW torsions
RR: BT drop leafs, Beefed Taco drop blocks
SD YOTA is offline   Reply With Quote
Old 01-10-2009, 02:38 AM   #5
JamesD
Veteran
JamesD's Avatar
Truck: 93 Reg cab
Quote:
SO YOUR THE ONE HE SOLD THEM TOO! YOU BASTARD! I WAS GOING TO GET THEM BUT YOU WERE CLOSER!
James
__________________
Old 01-10-2009, 02:39 AM   #6
JamesD
Veteran
JamesD's Avatar
Truck: 93 Reg cab
16x9 with 0 offset
Man this is confusing! So I can safely run the 16x7's all the way around? I can safely run the 16x8F all the way around? So stay away from 16x8R's and 16x9's, correct?
James
__________________
Old 01-12-2009, 09:09 PM   #7
SD YOTA
Toyotaholic
SD YOTA's Avatar
Quote:
So I can safely run the 16x7's all the way around? yes.
I can safely run the 16x8F all the way around? yes.
So stay away from 16x8R's and 16x9's, correct? correct
unless you run minimal drop and the right size tire combo, yea....... you'd be chasing after rub issues otherwise.
James
its not too confusing if you break it down 1 by one. each measurement i gave was one style of wheel. in total, they made 4 different wheels.
__________________
Old 01-12-2009, 10:04 PM   #8
4age-turbo
Newbie
4age-turbo's Avatar
16x9 all the way around......
[IMG][/IMG]
[IMG][/IMG]
4age-turbo is offline   Reply With Quote
Old 01-13-2009, 08:40 PM   #9
CinNAMmon
Toyotaholic
CinNAMmon's Avatar
Truck: 94xcab22RE4spdautoDLX
time to go find some! lol
__________________
CinNAMmon
B/J flip, crank'd torsions and 3" Drop blocks. Fire Hydrant Killer
CinNAMmon is offline   Reply With Quote
Old 01-20-2009, 02:29 PM   #10
Member
SD Yota is right in the sizes.
James,
You will be fine with the 16x7 all around. The 16x8 +18 and 16x9 +0 are very rare and people want a grip for them. The 16x7+18 and 16X8 -11 are easy to find but they are beat to hell sometimes.
4age turbo,
Sorry to tell you this but you have 16x8s all around. The fact that your rim has 2 steps in the lip is the tell tale sign (along with the 16x8 stamped on the backside). The 16x9 rims have 1 step in the lip because the face of the rim is pushed out flush with the second lip. In fact, the 16x8 rear rim actually has a deeper dish and offset than the 16x9.
I'm running 16x9 all around on my rig.
yotarip is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
ToyotaMinis.com - Dedicated to Toyota Stout, Hilux, and Pickup Owners
This site is privately owned and is not affiliated with Toyota Motor Corporation
© 2006-2009 Toyota Minis
Web Design and Hosting by Torx Media
