Anyone in the socal area have a lead on a truck or car being parted out, Or if you have an engine just hanging around let me know. I need either a running 20R, 22R, or a healthy early 22R bottom end. Im running through CL everyday but not everyone believes in the internet lol. If you have anything shoot a PM.
Intake, is different, but I think it is mostly going to be the cam that's different. Well besides the computer that controls it. IF i am wrong, feel free to correct me.
81+ 22R intake manifolds bolt right to the 85-95 block FWIW. The difference in the cam is negligible. if you have a mechanical fuel pump you will have to pop off the half moon crescent in front, remove the bolt going through the timing chain procket into your cam, and swap on the oval drive gear for the mechanical fuel pump in p[lace of the spacer that goes behind the distributor drive gear in order to be able to use your mechanical fuel pump.
I ended up buying an engine already. Either way thats a pic of what looks like a RTE but theyre saying its a 95
